Nick Roepke
New User
ok i have a 51 farmall m and the motor just aint running right the distributor is a bit off and i am not sure how to time it just right it seems to intermidently miss at hi and low rpm's. and i don't mean it spudders every once in a while like those old tractors do it compleatly misses and the motors rpm's seam to flote around could this be a problem with the carb not getting enough fuel from the tank? or could i have trouble with the govorner? and when i turn the distributer clockwise the motor will bi*ch and sound like it's under load and if i turn it counterclockwise the motor will slow down and sound like it is running "sloppy" with setting should it be closest to? should it run loosy or almost bi*chy?
