ken house
cub hydraulic lift, lifts o. k. but lift is not smooth, jumps and jerks. i recently bought the cub and it was quite low on fluid. maybe it will smooth out after a while.
Is there a hydraulic filter/screen on the 48? do not see one.
possibly draining and filling with clean fluid will help.
It has air in it from being low. It should work out with use. Try using it full travel. If it has an implement or Mower, disconnect it from the lift to run it through full travel. Jim
