What is this bracket for?
I have a bracket with a hole through it on the gas tank mount below the belt pulley lever, you can see in the picture I have the black starter cable tucked in behind it, what is that bracket for? I am considering mounting a hour meter on it.
I think that bracket is for the radiator shutter control rod. If you don't have shutters, you don't have the control rod, so you can use it for anything you want.
