International 404 pistons
I am rebuilding my International 404 engine. I have ordered the sleeves and pistons six times only to be refunded because they can't get the parts. They have two sets in the books. One set before serial number 100500 and one after. I am looking for sleeves and pistons for the early serial number. Can anyone offer some help as to where i can find them!
Thanks,
Mark G. Huggins
I just looked in HY-capacity catalog and they list only one set and that is above that Engine serial number. That is engine serial number and not tractor number.
404 engine serial numbers stated at 100501. Maybe you are using the tractor serial number.
Think this site lists piston and sleeves for the tractor, though its not real clear to me in the description if its 100500 down or over.
Both of you gentlemen are correct in your comments. I ordered these items from six different dealers including "YT Mag." All have taken my money and later refunded it due to parts being unavailable. I wander if I could use the available pistons and change the head? The sleeves and rings are the same, only the pistons are different.
My older Sealed Power says before 3100501 use SL2137 assembly. Piston only (#2137) fits from #20287 to 100501.
Not sure I understand, think you stated in the original post wanting pistons below 100501, but as I indicated in the other post if its a 404 engine they started at engine # 100501. All original 404 engines should be 100501 or higher.
Alright fellows, I have made a mistake. SORRY! The pistons and sleeves I am looking for are 100501> higher. These are the ones that don't seem to be available anywhere. I talked to someone at AGKITS and they helped me run the numbers and confirmed this. They were the most knowledgeable of any vender I have spoken with thus far. Sorry for the bad information, I'm kinda new at this.
Mark
