Hydraulic problem IH245
Anonymous-0
When I shut my tractor off last fall the hydraulics (3 point) worked. When I start it up this spring, 3 point won't raise. I changed oil and cleaned filter. What happened?
There are two CaseIH 245 tractors one big, one small.
In either case the Hydraulic pump needs to be primed. Putting 20psi (no more) of air pressure in the fill hole with the vent plugged if it has one, will usually do the trick. Jim
