Head studs on an H
ellson
I took the head off my H over a year ago and labeled which stud was the long one and have since lost the diagram
Can someone tell me where the long stud goes
Two of the long studs go on the back left side to mount the throttle bracket. There other two go in the center row where the two tubes are located that run through the head. The ones where the tubes are located also use a heavy washer under the nut,
