Farmallhal
Recently purchased a 1967 Farmall 656 gas tractor and have been reading through the Owner's Manual as to specifics unique to the tractor as I have never had a 6 cyl. Farmall before. I know you have beliefs on the proper fuel to be used and would like to start it's life off with me on the right track. The manual states "this engine is designed to operate on gasoline with a 93 minimum octane rating (research method)" so think I will be needing to use preminum fuel with this one. Gas today (unlike pre-ethenol days) has an octane rating based on the research method along with another standard which is averaged I believe. What gasoline product should I be using in current octane ratings with this tractor? The tractor's main use will be with my New Holland 273 small square baler and with a 10' Bush Hog clipping summer weedy growth on my pastures. It may get some tillage type use later when I need to replant some of my hay fields once I obtain a plow for it. Thanks much for any and all responses relative to this matter, Hal.
