3514 IH Hoe Fan Pully
Plowboypg
New User
I am currently working on an IH 3514 backhoe which had the bearings going out in the fan assembly. Needless to say, my hired man broke the pulley and the mounting bracket which bolts to the block. I am in need of both parts and was wondering if any one has the part numbers or a schematic and any suggestions as to where to purchase? This is a fan on a d188 diesel I belive. Any help would be greatly appreciated.
Regards,
Dave
jimb2,
This assembly is not located on the water pump. It is just a bracket with cast mounts that bolt directly on th front of the block. I guess it may not be a d188, but is definetely diesel with 4 cylinders. The pulley is 5.25 inches.
The D188 engine is a four cylinder version of the D282. You should be able to find the parts you need from a gas or diesel 460/560/660. The same parts would also have been used on 706 and 656 along with some others.
