Fuel Gauge 986
with the aux tank under the left fender, there are two sending units wired in series. i forget which order, but if you find the wire from the gauge and ground that, you should tell if the gauge works.
(quoted from post at 12:47:37 06/15/12) with the aux tank under the left fender, there are two sending units wired in series. i forget which order, but if you find the wire from the gauge and ground that, you should tell if the gauge works.
The wire comes from the gauge to the aux sender and then to the main tank sender and then to ground.
To check the gauge just ground the wire from the gauge and see it it moves. If not then check the wire and then the gauge.
