Anonymous-0
I have a SUPER W-4. I cannot get the hub off the axle. Here's what I have done so far.
Removed wheel, soaked the area with pb blaster, built & used a large homemade puller with 1" screw, applied lots of pressure with huge wrench & cheater bar, pounded on puller screw with sledge while under pressure, pounded (with discretion on hub while under pressure, drilled oilhole thru hub into keyway & used penetrant, did everything short of dynamite. Any suggestions??
Thanks in advance.
mrpete
Thanks in advance.
mrpete
