Tony_Idaho
OK, I just took apart my Oil filled air filter. I noticed that when I pulled the air canister off, the engine ran much better. So I figured air flow. Took the clamp off the bottom, and found that there was little to none oil in the bottom of the canister, with some water. Proceeded to clean up, then looked at the main part of the air filter. Looks like it is made up of steel wool of some kind. but it is all gummed up with black sludge. I've tried break cleaner to no avail and also dunked in gas. It made the gas turn black pretty quick, but the sludge remains. Doesn't look like it was ever made to remove and replace with new steel wool, because it has notches punched into it so it doe not move.
So, how do I clean out the darn thing?
Thanks
Tony
Thanks
Tony
