Woods Mower on Super C
DelMN
I have a Woods 59 mower on a Farmall Cub. I would like to Put on my Super C. I would probably just get the kit from Woods, but is there any other issues?
The cub pto turns in the opposite direction then all the other farmalls. Don’t know if putting a twist in a belt would fix that or not.
On the Super C, the mower blades will run backwards. Even if you put correct-rotation blades on the mower, the bolts that hold them are reverse thread and will unscrew eventually.
All you need to do is rewing the belt on the center spindle and you will have the correct rotation for the blades same belt ive done it a couple of times.
