I figured out the carb, started it last night and it ran better than before! It came up to temp and stayed at around 160. Came back this morning to re-tighten head and reset valves, began to turn the motor over and water dumped out of the #3 cylindar, so im guessing a cracked block (a crack I could not see when I had it apart)?
I put it all back together, started the tractor and the water in the cylindar came out and the tractor ran great again with no water dumping out of the manifold, am I missing something, could it be a blown motor/cracked sleeve? (head is perfect)
Thanks for any advice guys, im a little upset so im going to walk away from it today and go look at another block we have in the M grave yard....
