I do not know the 154 but if you look on the left side of this page under research and info then 3 point specs. you should be able to find out if you have a cat 0 or cat1 3 point. If you have the Cat 1 you can pretty much use most any thing built for the under 50HP tractor with in reason that is because some stuff might be a bit to heavy to lift
The cub 154 3-pt hitch is cat I, however if you envision using 3-pt equipment that's PTO powered, be aware that the cub PTO is a non-standard size, runs backward compared to normal, and turns at engine speed rather than standard 540RPM.
