Will a Super C mounted plow fit on a Super A?
Zachary Hoyt
I have the impression that the SA would have used a 1 bottom plow,
but I am not sure. Local buyer is interested in the Super C mounted
plow I have that works off the touch control system. My other
concern is whether the axle housing brackets would fit. Any advice
will be much appreciated.
Zach
It won't fit without severe modification, and then it probably won't ever work right.
Cutting up that plow would be a shame because they're kinda rare if you ask me.
IIRC, the Super A could have a 1-bottom 16" or 2-bottom 12" plow, but it was a completely different setup from the Super C.
I wouldn't cut up that plow should be plenty of plows for that Super A around. If it has the fasthitch it will bring a good price. Advertise
it on Classified Ads. .Hal
No, because the A design is a offset one row tractor with drop type rear axles, whereas the C design is a centered two row tractor with straight rear axles. Implements do not interchange between these two different designed tractor types.
Harold H
(quoted from post at 06:44:07 07/31/12) I wouldn't cut up that plow should be plenty of plows for that Super A around. If it has the fasthitch it will bring a good price. Advertise
It *IS* or *WAS* on the classifieds... Good price too.
This is probably the only serious bite he's had.
