F-30 Flywheel Help Needed
BT in NE
Can anyone tell me if I can install my flywheel 180 degrees from how I removed it? The reason I ask is there is a crack parallel with the groove the tapered pin fits into, about half the length of where the rear seal rides. I noticed there are two sets of timing marks stamped on it, maybe for this reason? Just wondering what would be a good alternative as I am trying to get this thing ready for a show on Aug 12th. Any help would be greatly appreciated. BT
(quoted from post at 19:17:13 08/03/12) Can anyone tell me if I can install my flywheel 180 degrees from how I removed it? The reason I ask is there is a crack parallel with the groove the tapered pin fits into, about half the length of where the rear seal rides. I noticed there are two sets of timing marks stamped on it, maybe for this reason? Just wondering what would be a good alternative as I am trying to get this thing ready for a show on Aug 12th. Any help would be greatly appreciated. BT
If its cracked I think I would contact Nebraskacowman and get one that isn't.
Using a cracked flywheel or pulley is flirting with disaster.......seriously !
Find another flywheel, else you may spend part of the show in the hospital. Cracked pulleys & flywheels can explode at speed !
Is there a keyway cut in the opposite side, Yes, I don't see why not. "at speed" of 1300 rpm I doubt it would "fly" apart. I do believe I have another flywheel if you decide you need it.
