"Christmas Tree" Valve on an H
WI Dave
If anybody has pics of a Christmas tree valve on an H, please post them. I've got the valve, but it had none of the plumbing required. I've been test-fitting it, and I'd love to see a pic of one actually on an H. I've seen them on M's, SM's, etc., but never on an H.
Here is the instructions. I know the one photos is sideways but it didn't scan well the other way.
So what does a selective lift control valve give you operationally? Do the 3 slots allow independent control of 3 two way cylinders?
Maybe what I thought a "Christmas tree" valve is, is wrong? I don't know. Anyhow, the valve I have shown was used on a cultivator. If you used the middle slot then everything raised or lowered at the same time. If you used the left or right slot then the left or right cylinders would work independent of each other. The photo I have shown we have a Woods belly mower on our H and we use the valve in the middle slot to work a one way cylinder to lift the deck.
early Super H which should be almost the same
second pic is removed, so you can see the hook-ups
ps not to steal the thread, but will a standard 4 mounting hole belt pulley
fit the pulley drive pictured?
