farmall c value these days
I would say as a complete unit $500 if the tires are any good. Parted out you'd get quite a bit more out of it.
Zach
If you are willing to fix the engine or replace the block, my max would be $700, provided straight tin and good tires along with no transmission problems, etc.
They weigh about 3000 lbs and scrap is around $12 per hundred weight here in western, pa. That is $360. You maybe could sell the tires and rims for $500 or so. You might be able to sell some of the other parts and make a couple of hundred.
