Super C Farmall PART
Anonymous-0
I'm looking for a wide front for my Super C.
Will one from a 240 farmall work?
I am also looking for a charr lynn power steering motor .
Please advise
By the time you add a p/s pump,pulleys and try to fit the toque motor in, I would just buy another tractor. I would estimate you are looking at 1500.00 including the wide front.
IF memory serves,the "240" front end won"t fit,center castings has a different bolt pattern,along with a different setup at the rear support.The correct ones are out there,as the "C" (With a couple of design changes),"SC",200"s,and "230"s,used the same unit.I suppose one could install PS on one of these (Seen a unit on a "140" years ago),but I"m not aware of one on a "C" or "SC".Perhaps you could be the first on your block-
