Tractor starts and runs good on gas and when I switch over to diesel it just dies. When the tractor was put away last winter everything worked well. This spring I went to start it and started on gas but, acted like it was dieseling while running shut it down. About a month later when I had time I went to start it and starter would not work. We pulled started it on gas and it started and ran fine but, Gauge on injection pump would not show pressure. I had the starter fixed replaced both filters,cleaned water trap and cleaned filter in the side of the pump. Bled trap,aux filter and both had good diesel flow. Started tractor in gas moved engine speed lever into Diesel and bled final filter with good flow and then each injector individually and all squirted fuel at least 6' across the room. Any ideas what is wrong? Thanks!
