gamehunter56474
New User
I recently purchased a live power pump with manifold and distributor included from ebay for $75. Not knowing if it was a good, functional unit I installed it, and it works perfectly. Now that I have enough oil pressure to tear the front end of the tractor completely off, I want to upgrade the camshaft gear. I"m told using a loader with the original camshaft gear is risky. I have found from a local salvage yard a 6664-DB gear for $45, which I"m told is the best gear possible. I need some good instructions on replacing that. Ideally I would like to remove the front cover and put a gear puller on it and jerk it off, no pun intended. I would really like to avoid removing the cam shaft itself, unless it is really easy. Any help would be really appreciated.
