jbp
There are three hydraulic outlets on the Farmall H liftall. Is any particular one prefered for such duty as a remote on a wheel disc or other such implement? Thanks, Joe
The most forward outlet on the left side (as you sit on the seat) and the right outlet are plumbed together internally. The rear one on the left will lift equally but can lower slightly later.
I would use either of the forward ones.
Remember, this system is pressure up & gravity down.
If you want two way(up and down)pressure do this: Put a hose from right pump outlet to a two-way (single lever) valve inlet. Then run a hose from outlet side of valve to oil filler tube. On the filler tube remove cap, put in a pipe tee. short length of pipe nipple and cap. From the side of tee hook up your return hose from valve. Your set togo for up and down pressure. Oh, I hooked a tarp strap to the pump lever to keep it on. Len
