Farmall 460 fast hitch.
Just asking out there anybody looking for a complete fast hitch for this tractor a buddy of mine just bought this tractor a is maybe going to change to a regular hitch just because only going to be used for rides and so on and it is much easier to get on and off of am looking for a regular draw bar also.
He should be able to trade with about anyone looking for a fast hitch. I watched each sale at an auction last Friday.
Fast hitch $450. Standard drawbar $25.
Gary
If the fast hitch is in good condition and the linkages and valve is working properly DO NOT SEPERATE as it might be hard to get it properly installed and working on a different tractor. Tractor will be worth more with a working fast hitch! Armand
Give a try like what I do. I set the hitch with the hydraulics to the mid level position. I then disconnect each side, one at a time and move the upright shaft forward to where the top arms pivot and pin them in the holes provided. One side you move just the pin and the other the whole pivot is moved in the hole. Once that is done the top shaft is lowered down all the way and now it is more like the standard hitch for getting on and off. At least you can use the fast hitch when you need it later without changeing all those parts. I myself have two of the standard hitchs from a 560 on the shop floor from parting out one and putting a fast hitch on the other 560.
