Thanks Delta Red. Mines an industrial. Water pump went out and havent been able to find anyone to rebuild it. Any suggestions?
Hi, 2444 and 444 have the same BD-154 Diesel engine unless you have a rare gas version. The block is slightly different between the 2444 and 444 but the water pump should be same.
I looked up in CNH Parts:
Water Pump 424,2424,444 and 2444
3042304R91 BEARING, water pump spindle
704216R4 BODY, water pump
B414D,3414,3444 and 7000 Forklift:
The bearing is usually the part that fails and allows coolant to leak. The bearing can be changed if you have access to a press but otherwise the casting body will break. Years ago when we had B414D,434 and 384, our local IH dealer carried re-manufactured water pumps.
JimB
