Just went to start the M, hit the starter button and it turned over but refused to fire. Tweeked a couple things, hit the button, wouldnt fire. I had oil dripping from the spot where the oil gauge goes into the block (didnt tighten enough) so I have oil circulating, hooked up my spark tester, hit the button and the shocked i took almost put me on the ground so I have spark. I turned the gas off, took out the drain plug and no gas came out and I do have flow through the gas line. I took the bowl off, cleaned everything again, reset the float to 1 5/16" like the manuel said, put it all back together and still no gas going to the carb. am I setting the float wrong? the book shows the measurement with the float level.
