super C hydrolics
blunted
has any one worked on them and know how to adjust to there potenchial? the 2 levers dont want to move, and the main lever only brings it up about 6 inches. also the clutch grabs big time , but no sign of leeking oil. thanks
Before you start any other repairs, remove the two rods from the touch-levers, remove the two "C" shaped covers over the levers and spray at least one-half can of Blaster or some other solvent into the lower portions of the levers housing. Don't stop until both levers work freely and without any resistance. Then, go to the next problem.
You need to unhook the levers and get them free as they are rusted probably. Then with the controls unhooked you can move the controls on the unit to see if the system works. Have you checked the hy fluid and cleaned the screen. The guard over the lift levers is easily removed just snaps ove them.Sometimes they are bound up pretty good so patience.WD-40 ect can be used.
What is "the main lever?"
What is "it" that comes up 6 inches?
On a Super C you typically have the two levers next to the throttle that control the Touch Control rockshafts. These are stuck, correct?
Optional on a Super C is a remote valve. Is that what you mean by "the main lever?"
Also optional on a Super C is the fast hitch. Is that the "it" that comes up 6 inches when you move "the main lever?"
You've got to help us help you. All we have are your words so you need to be as precise and descriptive as you can, unless you can post pictures.
