Im building farmall m tractor to do a little pulling and ive got a new reproduction farmall 450 lp head and manifold, farmall 400 motor, 400 crankshaft , stock 400 cam, 450 carb, 400 govenor,electronic ignition, and i plan on putting the 4 1/8 inch overbore that has the stepped head high compression piston from A&I Products in this block, and using stock stroke! does anyone have any idea on what kind of power im looking at here??and will i have to cut a little off of the top of the piston due to clearence issues ?
my M now has flat top pistons in it now with the 4 inch over bore and the 8060 head with the (lp manifold) and it made a solid 50 horse after new plugs a good carb cleaning and adjusting the timing .
any help with be helpful!
thanks for looking!
thanks for looking!
