Farmall Super A-140 Side Dresser - How to Hook Up???
RTR
I need help hooking up the drive chain on the 140 side dresser. I am not sure as to how it goes on there with the small tensioner gear. Pictures would help out nicely. Every which way I've tried to put it, either the top chain rubs against the bottom of the torque tube, or the 2 chains rub each other. I can't figure out which way it goes.
This is what I am talking about. It jumped off after I backed straight up 10 ft. Before it was jut loose enough to roll off at the end of a turn. Took out a link then got it on and then it popped off after I backed up
loosen the idler and position it ahead of the rear sprocket, instead of the middle of the chain see if that helps,may be wrong but i'm thinking that is the way mine is
