Frontend Loader on a 444 international
Dlong
New User
I have an international 444 gas burner with power steering that I am adding a front end loader.
Can anyone tell me where to connect the pressure side of the loader control valve?
Can I cut the pressure line after the power steering splitter valve and before it goes into the rear hydraulic valve under the front of the seat, then run it to the IN on the loader control valve and run the OUT (return) on the loader valve back to the other end where I cut it?
This way it would circulate through the open center loader valve and continue to the rear lift hydraulics.
Thanks
Darryl
Hi Darryl, usual hookup was to cut the pressure
line going to hydraulic reservoir in front of the
left brake pedal. At one time IH had a kit with 2
replacement hi pressure lines that replaced the 1
solid line and you connected in and out of loader
valve to the ends of these lines. So loader valve
in from pump side of cut hi pressure line, out to
hi pressure line to hydraulic reservoir and dump
from loader valve to pipe T into hydraulic
reservoir filler plug.
JimB
