factory ih w/f question
bbaro
is the lower cast front bolster the same on a 300/400 factory wide front, i have looked in the parts books, it looks like the parts are for a high clear only, for the heck of it i checked the part numbers for a schwartz and they have the same part numbers. some ads for the repro. bolsters list they will fit a 300/350 and some dont. thanks
Cast piece the axle tube pin goes through is the same. Same tube also. If I remember correct the wide fronts for the regular Farmall 300 and 400 tractors is shown in the attachment section of the parts books. Wide front for a high clear was standard equipment, so its found in the regular sections of the parts books.
Only thing that keeps a 300 and 400 wide front with cast wheels already on from fitting the other tractor is the steering arm bolt pattern and the rear support that goes to the frame rails. Original 300 ones used a different size spindle that a 400 though.
thanks for the quick reply D Slater, i checked under attachments and there it was. thanks again
