Baelee05
Thought I had the correct seat for my 39 M but have discovered that some of what I have is incorrect. I have the bracket and bracket support with the big bolts and spring that sit on the deck. I have the seat itself but need everything in between the pan and the deck bracket. I have posted an ad in the classifieds with part numbers I need. Thanks.
Oops! That wasn't very smart of me was it? Rats is something I say in lieu of cursing sometimes. I should have known this would cause confusion. Sorry. Duh!
(quoted from post at 15:33:13 12/14/12) Thought I had the correct seat for my 39 M but have discovered that some of what I have is incorrect. I have the bracket and bracket support with the big bolts and spring that sit on the deck. I have the seat itself but need everything in between the pan and the deck bracket. I have posted an ad in the classifieds with part numbers I need. Thanks.
Did all of the '39s have that channel iron style seat? Or did the later '39s have the pipe frame style?
Too lazy to look up the serial break, but I think that seat and trans cover were used until sometime in 1940.
This would be the correct seat for a 1939 and early 1940. The seat pan would have black canvas with brass rivits around the edge.
I have an early 40 M March I think, It has the notch in the deck I was told but don’t have proof that the rear axle bearings deck and seat changes were about the same time. I bought mine years ago with a later seat mounted on it, so I don’t have the original.
I did however design a seat bracket that used the bent pipe type seat frame and the original large hold down bolt it does look somewhat original
When I painted it years ago I found that the casting numbers of one front wheel where years newer. I also found welds on one frame rail leading me to believe the tractor was in an accident or a roll over.
the bottem plate is the hard one. I had that and made the rest for my H useing this one as a template There is an add in Red Power magazine for a guy that sells all the parts but there not cheap but neather is an original. This picture is an original and I gave $375 for it about 7 years ago but its as nice as you can find. If you want the contact info let me know
The 1939 models had a different steering wheel too is should be all black and covered They make a reproductition one but it is 16" the right one for an M is 18" i came across a new original one on ebay about a year ago
anther item is the mags on the early ones used a cable to ground out to stop the engine. Here is the part for the mag the cable is like a choke cable and has an "S" stamped in the knob they are extreamly hard to find but I did find one and am trying to repair it now.
Thanks for all that info Paul. My M has none of those things you pictured. If all of those things were readily available I might pursue it but honestly at this point I don"t really think I am interested in taking this tractor to that level. I do want to get the seat right but I think I am going to stop there. Thanks for all of the info!
