Farmall 400 fast hitch question
Nebraska Kirk
Does anyone have a picture of how the hooked rod for lifting the latches is stored on the tractor? My parts book shows the 2 little mounting clips and mentions 'battery box'. But having never seen the rod in it's stored position, I am unsure how it mounts.
On my 300, the flat bracket sits on the rear left corner of the
transmission cover and the angled bracket is bolted below it
on a bracket for the fasthitch.
If its this model hitch a sloted bracket went on where the duckbill support is bolted to the top cover, and another at the second or maybe third in case my memory is off mounting bolt down from the top for the left side support plate.
If its the other type hitch the 2 brackets were on the battery box. Didn't add that one clip on front right seat bracket and one on the right rear for a fast hitch with traction control.
Does your 400 have the early style ( 2 hyd cyinders 1 3x8 on the rear & 1 2.5 x8 along the right side )
or the later one with traction control ( big lever to the left of the operator, and only one cylinder in the rear.
If it's early style I can take a pic of my F300 for you.
