1066 IH help
Anonymous-0
I have a 1066 IH that the hydro went out of it, the fellow put a good hydro out of a 100 IH in ity but did not get the lines hooked up, it is a bit different than the 1066 hydro , I was wondering if someone knows how to hook the lines up correct ?
(quoted from post at 17:07:42 01/07/13) I have a 1066 IH that the hydro went out of it, the fellow put a good hydro out of a 100 IH in ity but did not get the lines hooked up, it is a bit different than the 1066 hydro , I was wondering if someone knows how to hook the lines up correct ?
Which lines are you wondering about?
There was a change in where one of the steering lines attached to the MCV but if I remember correctly there was no change in the MCV itself. The change eliminated a Tee fitting and used a shorter line.
