This a Farmall seat pan or an aftermarket seat ?
On Farmallhal's suggestion I decided I'd send my seat pan off to Darrel to have recovered. I contacted Darrel by email and he said I should check the lip to make sure it is in good shape so he can open it up, I don't see a lip. I knew I had an aftermarket Flow-ting seat base, but I assumed they used the original Farmall seat pan on it, now after seeing Patrick HDM's pipe seat picture I don't think so.
No that is an aftermarket seat i have a farmall H and M with that same seat not sure what company made them.
I believe some of the early letter series tractors came with a non-upholstered seat. I don't know if it was very early ones, war tractors or what. That is what this seat pan looks like.
(quoted from post at 21:05:36 01/08/13) No that is an aftermarket seat i have a farmall H and M with that same seat not sure what company made them.
I think it is a Knoedler aka "Suicide Seat" because the one my neighbor has tries to throw you off the back of the tractor.
The seat support is aftermarket. The seat pan is original IH for the early H and M. The early H and M tractors could have been upholstered or upholstered. The upholstered pans of the style shown, would have had the material riveted to the pan (lots of holes around the rim). These early pans are also much thinner than the later style, and are usually cracked.
The H,Ms didnt have the locking rod where the four holes are and the bar at the back has been removed. I have some A,B seat pans like the pic. No holes to hold the padded cover
Are you sure Gene? Why does it have the rail riveted on for the H & M? Did IH use the same basic pan for all models at first?
Thank you very much for all the help figuring this out.
So I guess I need to find an H or M seat, I am assuming an H or M seat will bolt right up to my Knoedler Flow-ting seat base, looks like currently have an optional flip back seat, but a standard 4 bolt seat might work.
Let me know if anyone has a pan they"d like to sell.
Yooper, I think some of these guys are getting the pictures confused, or maybe it's how this forum is displaying the comments, but to get to the point, that seat you have is exclusive to the mounting base it is on. It is a "one of a kind", and no one makes replacement seat pans to fit it. If you want it to be upholstered, you might be able to find a "slip-on" seat cover to fit it. Another option is to find a used, original pipe seat, or a used Monroe style seat which will offer a much improved ride and readily available brand new, upholstered seat pans.
The Farmall seat has a clip spot welded to the bottom with provision for four mounting bolts. Check the CIH web site for a picture. I could not get a good look at the bottom of your seat pan so I could not tell if it resembled the Farmall seat. I have a pan with two mounting bolts through the seat pan and it was an aftermarket seat. My 200 has a standard Farmall seat with four bolts. I guess I could get some pictures of the four bolt Farmall set up if you needed it. Send me an email if you need pictures.
The riveted part was added . The four holes are for the spring loaded rod that latched to the springs and the flat spots are where the stops or base mounts fastened. The rod at the back is not there or has been removed. I would guess the original purchase was from the original manufacture of that seat pan. Did IH make their seat pans ive never read about them. When you see that 220,000 As and Bs pluss the SA 100,130 and early 140 all used the same pans with lock rod and springs its a bunch So i buy the seat pan minus the rod and locking rod i can put any kind of mount on the bottom i want. Very interesting. Just like the thousands of Donaldson air cleaners for all the brands of tractors. Then the Guide lites on all tractors of that period numbers realy add up.
Ask Darrell if he has one as he usually has extras available as he buys them when he can find them at shows. I got one from him one time when mine was rusted beyond recovering, Hal.
I still think that is just the standard IH seat pan. They used the same stamping then riveted/welded the other parts needed for either the A/B or the H/M.
(quoted from post at 23:47:47 01/09/13) I still think that is just the standard IH seat pan. They used the same stamping then riveted/welded the other parts needed for either the A/B or the H/M.
Did you notice those square shaped indentations? I've never seen those on any IH made seat.
I agree they were on some H and M tractors. 41 model H that was in use on the farm as I grew up had one just like it except it was covered at one time. By the time I started using it the cover ring was the only thing left.
(quoted from post at 20:55:56 01/09/13)
Yes. They are needed on the A/B tractors.
(quoted from post at 05:39:56 01/10/13)
The H, M, through 450 do NOT have those indentations.
(quoted from post at 15:41:55 01/10/13) There are a lot of parts on a 450 that are not the same as an early M. This is one of them.
The 450 uses the same seat as used on the H with the Monroe seat.
(quoted from post at 12:45:19 01/10/13)
The seat in the original question is not a monroe seat.
