Finally some snow to plow!
[b:43eb20016c]Well we finally got some snow at least enough to plow. Fired up my new 300 rc and cleared out the driveway. After I first started it, and I might add I had to use the choke for the first time since I bought it, it ran a little rough. After moving snow for a while, it began to run smoother. Being as it was only about 5 degrees out, I will probably put a cover over the front of the grill to aid in the warming up and holding heat. The temp never really got off the peg as I used it.
Bruce[/b:43eb20016c]
like they say......without pics, it didn't happen!
it is important for the tractor to run in the design
temps about 160-180. reasons of which there are many
oil pressure way to high under load. amount of hp
the motor will put out and fuel economy only to name
a few. If the tractor does not have factory shutters
than it came with a thermostat and you need to
replace yours. Tractor should reach temp in under
ten minutes and a warm motor helps keep the operator
warm!
