rocklong
Can someone post me some pics of how the choke rod runs on a farmall m. It attaches to the outside of carb. Thanks
Not really for an "M". But when I re-installed the one on my 1950 "H" it didn"t fit, so I re-positined it, and it didn"t fit, so I re-positioned it, about 4 times, and finally it fit perfect. On a 1950 "H" it runs from the hole on the steering column Lift-All bracket, straight forward around the RIGHT side of the sediment bowl, then it takes a bend left, goes thru a 1/4" hole in a bracket on the gas tank support, then between there and the air filter oil reservoir, then it bends left, and attaches right up to the carb.
If you"re trying to make one, I wouldn"t bother, it"s hard steel, just get a choke cable from O"Reilly"s.
