TractorLinks.com
Show Parts for Model:
need help diagnosing farmall h no spark
cbrown
03-25-2013 05:22:20
ok need some insight, i have a a farmall h that was given to me its converted to 12v, i have no spark/ intermitint spark, this morning i pulled the center wire and had spark, 5 minutes later no spark from center wire, i have cleaned contact points have 12+v to the coil i believe the small condenser behind the cap may be bad, any thoughts?
cbrown
04-03-2013 04:36:14
 Re: need help diagnosing farmall h no spark in reply to cbrown, 03-25-2013 05:22:20
anyone know what the ground should be or does it not matter
Global Warmer
03-25-2013 18:44:28
The best money ive ever spent was to convert my super h to electronic ignition this website sells the kit. I fought with my tractor for months immediately after installing this kit it fired right off. It is very easy to install and fairly self explanatory. It made a world of difference for me.
gene bender
03-25-2013 05:48:24
When you change condenser make sure its from a good parts place I-H, Echlin or a name brand as some of the imports arent known for good service like those from TSC and other discount places.
David G
03-25-2013 05:26:41
I would make sure the points are opening. The rub bar gets worn down and the point may not be opening. The points should be .020 with the bar on a lobe.
I would then change condenser if you are sure the points are good.
cbrown
03-25-2013 05:45:38
 Re: need help diagnosing farmall h no spark in reply to David G, 03-25-2013 05:26:41
the gap is.020 it does open and close, i sanded between the two points, i can see sparking between two points, however no spark coming from coils center wire
Janicholson
03-25-2013 06:50:46
 Re: need help diagnosing farmall h no spark in reply to cbrown, 03-25-2013 05:45:38
With all components connected, put a test light on the distributor wire from the coil. If it flashes when cranking, I would replace the coil. Jim
El Toro
03-25-2013 06:26:16
I would try another rotor and coil wire. Hal
cbrown
03-25-2013 07:59:32
 Re: need help diagnosing farmall h no spark in reply to El Toro, 03-25-2013 06:26:16
update, i cleaned off even more and got spark to PLUGS, however i left the switch on for 15 minutes and coil is too hot to touch, does that mean the coil is shot, its stinks (smell) its so hot
cbrown
03-25-2013 10:07:18
 Re: need help diagnosing farmall h no spark in reply to cbrown, 03-25-2013 07:59:32
i let the coil cool off and spark came back, i think im going to pick up napa IC14SB 12v coil and see if that fixs it, does this seem to be a good guess, im not sure if it has a 12v or 6v coil on it but by it getting hot it may be a 6v
El Toro
03-25-2013 11:33:52
 Re: need help diagnosing farmall h no spark in reply to cbrown, 03-25-2013 10:07:18
You can tell easily whether you have a 6 or 12 volt battery by counting the battery cells. A 6 volt battery will have 3 cells and a 12 volt battery will have 6 cells. I think I didn't see a 12 volt battery until 1955 in a car. The military used a lot of them to get 24 volts. Hal
rustyfarmall
03-25-2013 10:47:14
A 12 volt conversion requires either adding a resistor ahead of the coil, or replacing the original coil with a 12 volt coil that does not require an external resistor. The IC14SB is a good choice.
cbrown
03-26-2013 04:27:23
 Re: need help diagnosing farmall h no spark in reply to rustyfarmall, 03-25-2013 10:47:14
im ordering a resistor this am, 1.82 ohms sound good, when i tested the coil the ohms where 2.0, so i think the 1.82 should be good, sound good to you guys, i have spark all the way to plugs now
Janicholson
03-26-2013 17:26:08
 Re: need help diagnosing farmall h no spark in reply to cbrown, 03-26-2013 04:27:23
DO it. Jim
cbrown
04-02-2013 06:06:02
 Re: need help diagnosing farmall h no spark in reply to Janicholson, 03-26-2013 17:26:08
well its a bit frustrating, but i got spark and it did run, but without using the resistor, here is a run down of what i have, and have done to it
1. 12v neg ground (the coil had ignition switch to neg and coil to positive when i got it running, is this correct or do they need to be switched)also coil resistence tests at 2.0 ohms when ignition is off
2. New condenser napa ih200
3 new plugs
4. points gapped at .019
5.i am ordering new napa parts- new cap IH350, rotor IH300 points cs 1600
cbrown
04-02-2013 06:26:04
 Re: need help diagnosing farmall h no spark in reply to cbrown, 04-02-2013 06:06:02
ALSO Want to add that i am using a 12v battery with negative ground, should i be using postive ground what would the difference be, thanks for the help sorry for a million questions
cview
04-02-2013 06:58:35
 Re: need help diagnosing farmall h no spark in reply to cbrown, 04-02-2013 06:26:04
ttt
cbrown
04-02-2013 06:15:45
trying to get to top of topocs
