Last year the H started to lope. Took the carb off and cleaned it. Made no difference. This spring I soaked the carb for 3 days and put in a new complete carb kit. Same thing still loping. I adjusted all jets and did not see any difference. The only thing that will make it smooth out is to run at 1/2 choke. I checked the main jet found nothing wrong and even wide open it does not make any difference. The governor is free but I have not been inside it. Any ideas?
Dan - If running at partial choke stops the loping, problem is a chronic lean condition. A few common causes:
- leak at the carb to manifold flange
- leak at the manifold to head gasket
- a plugged carburetor port - especially the idle port in the carb throat by just above the throttle plate
- float level set too low
- broken idle mixture screw (note turning the screw IN makes the mixture richer)
- improperly assembled carburetor
Also do as Bouncer suggests: Check for good fuel flow into the carburetor. Remove the drain plug or cock from the bottom of the bowl - it should flow a solid stream of gas. If gas just dribbles out there's a restriction)
Sorry, it will run at half choke so it isn't the gov. A sloppy gov will make them lope, but they only smooth out with a load.
It may be a lean condition as others have stated. If it will pull a heavy load good for an extended period of time without the manifold starting to show red, forget the lean. It takes a while under load though to prove this out. A worn out goveror doesn't make them lope unless parts are sticking. A good active governor is much more prone to lope (surge) than a worn one. Notice the square machined spot on the lower rear corner of governor housing. Well, IH had some H tractors that were prone to surge so they made a surge adjustable screw available and it goes in that spot. It is not drilled. I have only seen two in my life (41 years working at IH dealer) and one of them is the 45 H my dad bought new and I have now. I don't know if it was on there when he bought it or installed later. IH did a couple other things to over come surgeing on different engines, but I don't remember them doing it on an H. The throttle butter fly is not exactly centered on some carbs and the degree number on the butter fly shows this and also the butterfly is beveled on the edges. Opposite on each side and has to be installed properly to operate correctly.
Just some extra things to think about. And, also, ethanol runs a little leaner so you may have to increase the main jet just a couple thousands. The gasoline engine main jets were pretty close to what became knows as a fixed jet in later years and main jets don't come with carb kits. Neither do air bleeds.
Blow out your fuel lines. Could be a bug plugging
them up. I had a farmall 12 that a larva crawled
through the strainer and spent the winter in the
fuel line.
(quoted from post at 17:34:47 04/07/13) It may be a lean condition as others have stated. If it will pull a heavy load good for an extended period of time without the manifold starting to show red, forget the lean. It takes a while under load though to prove this out. A worn out goveror doesn't make them lope unless parts are sticking. A good active governor is much more prone to lope (surge) than a worn one. Notice the square machined spot on the lower rear corner of governor housing. Well, IH had some H tractors that were prone to surge so they made a surge adjustable screw available and it goes in that spot. It is not drilled. I have only seen two in my life (41 years working at IH dealer) and one of them is the 45 H my dad bought new and I have now. I don't know if it was on there when he bought it or installed later. IH did a couple other things to over come surgeing on different engines, but I don't remember them doing it on an H. The throttle butter fly is not exactly centered on some carbs and the degree number on the butter fly shows this and also the butterfly is beveled on the edges. Opposite on each side and has to be installed properly to operate correctly.
So why do they tend to lope when you put a stiffer gov spring in? It seems a lot of guys (at tractor pulls) who play with their gov get a lope.
