burnsg2003
Ihave a c that i just redone. I left it with the 6 volt system positive ground system. THe problem is I could not get it to charge. I polarized the system checked the grounding, my wiring and found a trouble shooting guide on this sight still no luck. SO I took the generator and regulator to a shop and they tested both and said the regulator was bad. put everything back on including new regulator and
polarized the system and still does not work. If you turn on the switch ammeter shows discharge. When you start the tractor it shows discharge for a little while and returns to zero. If you turn on the lights it shows lots of discharge but eventually read zero. Any ideas or help would be appreciated. I am out of ideas unless the generator really isn't working. Thanks for your help
