b414 fuel line
Stating to dig into the 414. It looks like the fuel line has a pressure regualtor ( 1.5 inch diameter, aluminum pancake shape) in the fuel line. Is that what you think it is? is it necessary ( don't see it in the parts book). The thing has been sitting for 6 years but one think I always remembered about it is it would die when throttling up a little fast. the carb is new ( put on 6 years ago and used about 5 hours)
thoughts ? and thanks
I wish I could describe it better. It isnt a filter and actually has what appears to be a screw in the middle ( maybe an adjustment ?)
If it's on the side of the engine then it sounds to an awful lot like the mechanical fuel pump? Those usually had a small screw on the top holding everything together. A picture would be best. Sam
