240 hubs on a Super C
I have a set of IH 240/330 UT hubs I'm trying to put on a Super C, having a few problems. I have the outside bearing ok, but the inside is causing me problems. Is there a better hub than a 240 and if so what bearing should work. Cook's in Clinton said the 330 Utility and the 240 were the same?
Thank you,
Charlie
330 uses the 350 rear end, so it's different from the Super C/240 line.
I don't know who told you it was the same but they're wrong.
