The reason for a green question on the red forum is because I've had more luck here plus farmall is my favorite anyway.
A broken centering spring in the torque sensing system where the steering wheel shaft enters the first hydraulic components would be where I would start. JD has good online parts diagrams. Jim
(quoted from post at 09:01:05 05/11/13) . . . a green question on the red forum . . .
If you are going to do that, it would be nice if you mentioned the brand along with the model number. That way people don't have to guess whether it is a Wheel Horse, Belarus, Fendt, Claas, Long or some other brand that doesn't have it's own dedicated forum for such questons.
The question is a rather generic, power steering issue that could apply to several different brands. I think Janicholson pretty much nailed it.
if you need parts for a char lynn torque generating type unit check with a place called Force America they have individual parts for the system and seem to be reasonable price and friendly too. I have dealt with the one in Fort Dodge IA check out catalog page marked 104
force america catalog
(quoted from post at 07:01:05 05/11/13) The reason for a green question on the red forum is because I've had more luck here plus farmall is my favorite anyway.
I realize that, but you would have been much more clear if you stated it was a JD and what kind of PS system was on the tractor.
To center the steering on a jd 520 you need to take the nose off,slightly loosen the 4 3/8"bolts that attach the valve assembly to the steering box, and tap it forwords or back to center it.It would be much easier if you had an I&T manual.
