I can look tonight when I get home to where the manual is. For starters, do you have a 144 hole drum?
Casey in SD
Ok, this information is for a 144 hole drum and a 12T-15T combination. The driver needs to be a 10 and the driven needs to be a 17. That combo will be a touch light at 128700. The next step is a driver that is 11 and a driven that is 18. That will be a touch heavy at 133740. Good luck.
Casey in SD
