Rear Tires for M
John M Nowak
New User
I need to either match a rear tire < 13.6 x 38 "SafeMark Multi Angle"> or purchase two matching new ones. Where are the best deals <on line> for rear tractor tires? I'm in N Carolina and price is a concern. Thanks! Also - is this the best size for my M?
. . . trying to attach pic ! it's the LEFT rear I'm trying to match
13.6x38 is the most common size found on an M. Tires are no longer reasonably priced, but if you shop around at several farm tire dealers in your area, you might stumble across a pretty good deal.
I'm all for "made in the U.S.A.", but there are some imported brands that are just pretty good tires also.
Figure out what percent worn (or tread remaining) your good tire is and start shopping around, such as on Craigslist. Once in a while you'll find single tire. A single by itself shouldn't command as high a price as two in a set, since it's an oddball.
For about $250 should be able to find a good one. If your luck is like mine though, when I am looking I can never find what I want. It will be real easy to drop $1000 into the old girl.
