Farmall B Drawbar
mwilke
Does the drawbar on a Farmall B hook directly to the final drives? My Cub has brackets bolted to the final drive and the drawbar fits to these brackets. Based on the online parts diagram it looks like the B does not use brackets. I recently purchased a B without a drawbar and want add a drawbar. Thanks
There is 2 common types of draw bars for the B. One is a big horse shoe sort of thing that bolts to the final drives and then there is a swing draw bar that has another bar in front of the rear draw bar and has a pivot thing for it. I have at least one of the Horse shoe types on hand on a parts B I have and my e-mail is always open
The B has a one piece drawbar finding one thats not bent is the problem. You can also add a swinging one with an anchor bar which will let the swinging bar be moved from side to side for pulling something which would off-set it from center.
I have a good one in SE WI as well. Not bent at all, but does have some brackets that should be ground off to satisfy the correct police.
Yes, they bolt directly to the final drives.
