I posted a few days ago; the long adjustment rod on the side of the H has to be unthreaded all the way, leaving only one thread into the clutch pedal bracket. In tht position, there is 1" free travel of the pedal, which appears correct.
I have taken everything apart.
Clutch; The clutch itself has 1/8" material on each side, and no rivets scored through. Surfaces are glazed, though. Looks OK, but I have no idea.
Bearing; Had been lubed, turns real smooth, is the same thickness etc. as the one at the CNH dealer. It looks just fine.
Bolts; No obvious wear, nothingloose, nothjing sheared, nothing plainly wrong.
Any ideas, guys??
Any ideas, guys??
