I am still requesting help in identifying this IH 2-Row 2 Point Fast Hitch Planter.
It is driven by left press wheel, through a clutch that only pulls on forward movement. Right press wheel free-wheels in both directions.
This unit has an exposed transmission !!! Press wheel axle has a 1-piece gear set 520465R1 10 & 12 teeth. Driven by square-link chain, through a spring-loaded 3-roller idler. Countershaft is driven from press wheel to 1-piece gear set 5201060R1 8 & 10 & 14 teeth. In the center of the countershaft is a 15 tooth gear driving square-link chain through a 3-roller spring-loaded idler to Planter Units Drive Shaft. On the Planter Units Drive Shaft is a 1-piece gear set with 15 & 11 & 7 teeth (could not see a IH part number).
On each outboard end of the countershaft is a 10 tooth gear that must drive an optional fertilizer applicator or something.
Hopper has COTTON stamped on one boss, and part 621714R2. Underside of cotton hopper has 621704R2.
