Cub Power Unit, Looking for info
Haas
I'm looking for info regards a Cub Power unit. I've tried searching the archive website but have had no luck there. The nameplate on the power unit says Model U-1 and serial number is UCUB 6968. Anyone have any serial number information for the U-1 power units??
If the SN on the plate on the housing is 6968, then it was made in 1957, and probably one of the last ones made before they switched the names from the U-1 to the UC-60.
Do you happen to know the Engine SN and the Engine Cast Code? They are found on the left side of the engine. I could confirm the information above if I had those.
