Is this a 22-36?
yes it is a 22-36, as the water pump was added to the 15-30 model in 1929 along with an oil filter and other improvements like bigger bore and increase in rpm. it was then called the 22-36, but decals stayed at 15-30.
I would say it is a early 15-30. Unless you know the size of the pistons I would say it a 15-30. Also the early 15-30 had a narrow block
