Brady Miller
Gents,
I'm rebuilding a super m. The engine is stuck, I've heard to use diesel and transmission fluid to loosen the pistons against the liners. It has standard flat top pistons and standard 4" liners. I have put a pipe wrench on the crank and put some pressure with a cherry picker. It has been sitting for 5 years. I drained about 3/4 gallon of water out with the old oil. I am going to do a good inspection of the oil pump too. What do I need to look for on the oil pump? Any trick to free up the pistons? Thanks
